Where did you mount your W/alky pump?
Old 05-08-2006, 05:00 PM
enginjoe's Avatar
Default Where did you mount your W/alky pump?
I've done some searching and couldn't find any satisfactory info. So, anybody got any pics of where they mounted their pump for w/i? Also, is it important or does it help to put the nozzle before the MAF?
Thanks
Old 05-08-2006, 05:08 PM
Frost's Avatar
Nozzle AFTER the MAF.
Old 05-08-2006, 05:39 PM
swearitsstock's Avatar
i put my nozzle directly after the intercooler... most efficient there
are you using a check valve with the pump? if not make sure you mount the pump lower then the nozzle to prevent leaking when the car is sitting
Old 05-08-2006, 06:10 PM
enginjoe's Avatar
I have a check valve. I don't have the intercooler yet...
Old 05-08-2006, 06:12 PM
what brand alcohol/water injection kit do you guys use?
Old 05-08-2006, 08:21 PM
618HAWK's Avatar
I mounted my pump with my horns.
Made a bracket which holds the horns and pump.
Inlet is at the lowest point and I still have access to the pressures adjuster, through a hole in the lower splash shield once it is back on.
Not that is matters I went with Cooling Mist Unit ---Vari cool controler unit, mounted in the driver knee bolster.
This is how I plan to do my nozzles.....Did this set up on HUGGERS ORANGE SS .Yes a must to go after the MAF! this was in the mock up stage.
Old 05-09-2006, 02:02 AM
ws6charged's Avatar
hey 618 hawk whats up? i have a few ?'s can i run this unit with my n20- setup since it jets at the maf? actually i am not to sure how that combo would work with my n20 can you write back or pm me some info thanks.!
