mustang dyno numbers only plez
Basically, im trying to put together some info for a large database type of post. I want to start with this for now so it can get started.
Thus, if you can, please post your mustang dyno numbers only with a quick word on your combo, m6 or a4 (very important) operator, if you can, and/if you have any track times, plez imclude that as well if you can.
Thank you, this will go to the Anti-how much will I make threads foundation.
Thanks again!!
Thanks again!!
02 z28 m6
5k on the car slp lid, K&N, hollowed cats, & dynomouth exhaust
331 RWHP 360RWTQ 13.2 @110 2.3 60'
previous mods + hooker LT's crappy crimp bent y & magnaflow oem replacement muffler
lunati 222* 228* .534 .544 114 LSA hand ported 5.3s & TB 160 t-stat 4.10s
405 RWHP 408RWTQ 12.2 @117 1.9 60'
dang, 6 of 7 haven't posted their results in my thread on rear wheel power and track performance trends in this same forum. obZ, I gotta thread jack a little here... can you guys jump over to this thread and get your results posted along with your weight??
Thanks, TJ
Thanks, TJ
i already posted once but i went back to the dyno today(mustang dyno) i had some timing and fuel issued to be solved. so...we got her fixed and retuned the #'s were 463.0hp @6500 413.8tq@4,700. i gained 5hp and 13.9 tq more when we fixed the problems.
Any large cubed, autos or m6 on a stang dyno?
Mike C.: Those looks quite impressive, stock cubes i imagine, right? Those look like dynojet numbers with your same mods... where did you dyno it at if you dont mind me asking?
Mustang Dyno:
Dyno'd @ EPP brent did the dyno run .
499.4rwhp / 468rwtrq only ran up to 6400rpm running rich. Partial Tune via email TSP TUNE.
2001 T/A Ws6 M6
Motor Spec's: TSP 408 shortblock w/ AFR 225 heads (out the box)TSP GIANT 113 +2 ASP UD Pully,Fast 90mm Intake, NW 90mm TB, 85mm GM MAF, Hooker LT's, TSP Catted Y pipe, Borla Catback. Now I am running Pace setter LT'S with Pacesetter ORY' still working on the tune. Hope this helps ya
2001 T/A Ws6 M6
Last edited by Snapps; 05-15-2006 at 04:48 PM. Reason: forgot a few parts and trans. type
No, thats exactly what im looking for!!
Man, bobs dyno cant get a even number even if he tried...
Almost every number is like 499hp or 495 or 595hp. Its close to the next mark but not quite enough!!!
410rwhp / 393rwtrq 11.92@120 383-M6-9inch car is setup for RR/Autox. Car was about 90% done with tune at the time. Ran out of valve springs @ 5800 rpm.
I got a better Valve springs/Intake/TB/MAF and fuel system now. Just got to go back and get some new numbers.
