Power steering delete drivablity
I have a 94 LT1 car. I just got done with installing a low alternater setup, and got rid of the power steering. I didnt loop the lines just left them open. Is there any thing that can be done to make it easyer to drive with 275 size tires up front? Will looping the lines make it any better? The car was border line imposible to drive with the larger tires.
I do have skinnys, and im sure that they will help the problem, but im just looking for some tricks to help out with the larger tires.
Originally Posted by foggedz
A manual rack will not work with larger 17in rims. The manual will only work with skinnys.
Originally Posted by Moparnos (The SLP Guy)
anyone know the belt size with stock crank pulley?
I think I just about killed myself and Paul @ Thunder when attempting to test drive my car with a manual rack and 17" (275/40) tires. There would be just no way my Grover arms could handle it.
I've known guys try 16" wheels (245 or 255 tires). They ended up taking the racks off. PITA.
Skinnies drive with no problem at all. Just don't try to corner or panic stop with them.
Gates Micro V 6 rib 36.5 inch.
Thats off the top of my head but I think thats right.
FYI I have rebuilt the front suspension in my 94 and keeping the ball joints and tie rod ends lubed up helps with the manual steering.
If I remember correctly the stock ones don,t have grease fittings so you would have to install new ball joints.........just something to think about for the future if your going to keep the manual steering. I have gotten used to it so I am keeping it.
Originally Posted by Shon Herron
Finally, the 4rib belt is 35.5" long.
By the way IBWSjerry, it doesn,t look like your belt is going to line up.....you will probabley throw the belt if you run it like that.
Most of the PITA of my install was spacing it correctly so the belt was lined up right.
