Thread Size Question
Old 05-09-2006, 08:41 AM
1_Bad_LS1's Avatar
Default Thread Size Question
What size is the hole on the side of the head where the coolant temp semp goes?
thanks in advance
Old 05-09-2006, 08:56 AM
That's what she said...
TheBlurLS1's Avatar
https://ls1tech.com/forums/showthrea...hlight=fitting
Some good info in that thread, check post #21. Not sure if that's correct or not, but it's a start.
What are you trying to do?
Old 05-09-2006, 09:05 AM
1_Bad_LS1's Avatar
Thanks I will check that out...
I am running an autometer water temp sender into it...
Old 05-09-2006, 09:49 AM
TheBlurLS1's Avatar
https://ls1tech.com/forums/generation-iii-external-engine/503672-tb-bypass-h20-sending-unit-install.html
Check that thread out.
There is a plug on the passenger side head you can use for it too. Since both heads are identical, it will be on the opposite side. This way you won't have to mess with your factory sensor.
Old 05-09-2006, 11:15 AM
1_Bad_LS1's Avatar
I am trying to get a fitting to adapt to the hole in the passenger head, because that is a nice clean easy place to install!
That is why I am trying to find the thread size...
There is also a Engine coolant drain plug on the driver's side of the block that could be used... According to the guy at my local dealership...
