HPTuners Tuning Links
Old 05-09-2006, 10:24 AM
LS1TECH Sponsor
foff667's Avatar
Default HPTuners Tuning Links
Help File
HPTuners Forum
[/COLOR]General[/B]
Saving a VCM Suite Info Log-NEW!
VCM Editor
Reading your VCM
Writing Calibration to the VCM
Failed VCM Calibration Write - VCM Recovery
Changing Fan Settings - 160 Degree Thermostat
Applying a 1 Bar SD Enhancement
Applying a 2 Bar SD Enhancement
Using the Compare Feature
VCM Scanner
Adding and Removing PIDs
Creating a Custom PID and Adding a Custom PID to the Histogram
Creating a user defined EIO Input
Standalone Data Logging-NEW!
Creating and Saving Custom Histograms-NEW!
Using Plot Filtering in Histograms
Reading and Saving DTC's-NEW!
MISC
Creating a User Defined Output
Stock OS 1 bar SD Tuning How-To using a wideband oxygen sensor
HPTuners Editor quick start guide
Old 05-11-2006, 10:30 AM
LS1TECH Sponsor
foff667's Avatar
Default *new*
HPTuners SCANNER Quickstart Guide
Old 06-18-2007, 02:43 PM
Mels SS's Avatar
Tell me what this will do for my 06 Monte SS in simple terms and can I with very little
experience with tuners do the programs on the SS
Old 06-18-2007, 03:12 PM
LS1TECH Sponsor
foff667's Avatar
Sky is the limit as to what you can do really, raise rev limiters, speed limiters, adjust fueling, spark, Displacement on demand, scan the pcm, etc.
As far as can YOU do it, you get out of the program what you put into it. Meaning if you spend the time to read & learn about tuning you can do some wonderful things. If your not willing or able to put in the time you might want to consider having a shop do a starter tune for you so you can compare what they did as compared to your stock file. Another option would be to have a shop do a full dyno tune.
Old 06-18-2007, 04:38 PM
Mels SS's Avatar
Displacement on demand, raise rev limiters, speed limiters I wont this also How much HP gain can I get from the Tuner if done right.
Old 06-18-2007, 04:41 PM
LS1TECH Sponsor
foff667's Avatar
There are alot of variables, but a good tuner can usually grab 15+ hp out of most combinations thats not to say you can't gain more or less but thats about the norm from a good dyno tune. Just remember its not all about peak numbers but numbers under the curve & drivability that can be gained as well.
Old 12-22-2007, 10:16 AM
NotthisSS's Avatar
Im still confused on how the credits work. I dont know how to determine how many i need to accomplish my goals.
Old 12-23-2007, 08:31 AM
LS1TECH Sponsor
foff667's Avatar
What are your goals?
Old 12-23-2007, 12:06 PM
NotthisSS's Avatar
I just put on LT headers so i need to delete my rear 02 sensors, and delete my EGR and AIR systems. I also put on bigger wheels. But since i put on my headers and have not deleted those things my car has gone into this limp home mode and has been running terribly. i just want to be able to fix that. Thats my goal.
Old 12-23-2007, 02:23 PM
LS1TECH Sponsor
foff667's Avatar
Thats not a problem, basically you would just license your vehicle ONCE using 2 of the 8 credits that come with your unit & your done, you'll never need to relicense your vehicle EVER so you won't be affected or need to worry about a thing after that.
-Bill
Old 02-04-2008, 03:25 PM
Viper's Avatar
foff667, many of the links don't work anymore.
Old 02-04-2008, 03:33 PM
LS1TECH Sponsor
foff667's Avatar
I know, im working on finding a new hosting solution which will fix the issue.
godaddy.com boycott time lol
-Bill
Old 02-04-2008, 03:50 PM
Jditlfm's Avatar
as far as tuning for bugger injectors, I have searched and i have come up that i need to look at the Ifr tables? Not sure where they are on Hptuners for a 98 ls1. Then there is a formula to re scale the stock tables. Its hard to find clear information on this. Faq link to it is dead.
Old 02-04-2008, 07:36 PM
LS1TECH Sponsor
foff667's Avatar
All of the injector tables are under Fuel Control-General including the injector flow rate(ifr) table.
Old 02-04-2008, 07:46 PM
stangkiller2005's Avatar
this is really cool! thanks for the links! im going to be looking into buying hptuners soon. i really want to learn how to tune. ima start with my car. and go from there.
Old 02-05-2008, 06:50 AM
LS1TECH Sponsor
foff667's Avatar
links should be all up and functional now.
Old 02-05-2008, 07:27 AM
Viper's Avatar
Very nice, pictures always speak louder than words. Great job on the vids.
Old 02-05-2008, 09:43 AM
what is the difference with the standard and professional hptuners listed in your sig?
Old 02-05-2008, 10:00 AM
LS1TECH Sponsor
foff667's Avatar
http://www.hptuners.com/forum/showthread.php?t=2924
What does the MPVI Pro interface allow me to do over the Standard Version?
With our Pro interface, you can integrate 0-5v signals from various sensors such as EGT, Wide Band, fuel pressure and others right into our scanner. You will have real time data from those sensors right next to your standard scan tool data such as TPS, RPM, MPH, etc.
Our MPVI Pro interface also has black box data datalogging of up to 1hr 30mins built in. What this means is you are able to scan your vehicle without the use of a laptop using the interfaces record button. You can then take the interface into your home to transfer the log contents from the interface to the computer. If you have an MPVI Pro it will require no hardware modification. Also note that VCM Scanner comes with both interfaces regardless as it is part of our VCM Suite package.
Old 02-05-2008, 10:50 AM
cool! thanks for the info!
one more question.. with tunning. what do you recommend? i really want to learn. should i just mess around with it little by little, and working with it and my car? or look for a school that can teach me what is needed to know about air fuel, and all the things that need adjusting when it comes to tunning a car...
Quick Reply: HPTuners Tuning Links
