About to order drag rims and tires, need advice.
I am going to be getting a pair of prostars and ET Drags for the rear of my camaro. I realize that I am going to have to grind the calipers down with these. I dont know whether I should order the 15x10s or 15x8s. I am probably making about 400rwhp. I have 4.30's in a full spool 12bolt, if that helps make my decision. With the 15x8 I would probably run a 28x9 ET drag and with the 15x10 I would run a 28x10.5. With the 15x8 I wouldnt have to grind as much and it costs a little less, but I wouldnt have the traction that I would get from the wider rim/tire combo. I will check this post tonight after work and whatever the concensus is I will be buying.
