NW - FAST TB bolt question
Um, duh,
Does anyone know if the NW comes with new TB bolts? I dont seem to have more than one bolt that would work? Is the maniold supposed to come with them?
Thanks,
Dave
Thanks,
Dave
I found this thread
https://ls1tech.com/forums/generation-iii-external-engine/461554-mounting-fast-90-a.html
But what I don't get is, what bolts are supposed to hold down the front and back of the manifold?
Originally Posted by BADFNZ
I found this thread
https://ls1tech.com/forums/showthread.php?t=461554
Hold up. I just got an email from FAST and they said it doesnt come with throttle body bolts.
I'm not sure what you're referring to as the 1 throttle body bolt, but we do
not include them, nor do we have any of them. However, you should only use 4
to mount the throttle body to the intake.
-----Original Message-----
my fast 90 came with the 4 extra throttle body bolts and nuts, the front and back of the manifold were already bolted down with similar/or same bolts and nuts, it also came with bolts and nuts for the throttle cable bracket. the nw90mm came with the 1 extra long bolt for the top(no nut, only thing i had to buy). and i just used the fuel rail bolts of my old manifold.
That's what she said...
Speaking of rails...........
WE are getting railed on these FAST manifolds. They SHOULD come with port gaskets, they SHOULD come with stainless hardware, they SHOULD come with TB bolts, they SHOULD have a clip for the MAP sensor, and they SHOULD give head......... for the price.
Stripstar - To answer your question, you need to buy the bolts from a local hardware store. My NW TB did not come with any bolts.
Yea i was kinda dissapointed in the lack of bolts/gaskets and map sensor hole for the amount of money it costs.....but other than that it seems like a nice piece.
