15x10 pro stars..no spacer?
Old 05-09-2006, 08:41 PM
ls2 bait's Avatar
Default 15x10 pro stars..no spacer?
anyone successfully got them on w/o a spacer? i know im going to have to grind like crazy but i dont like running spacers on the rear wheels and id prefer not to put very long studs in the rear because these are weekend only rims. (track use) if not whats the smallest spacer u have used.
Old 05-09-2006, 08:49 PM
LS69TA's Avatar
Yea, you'll have to grind a good bit, but they fit without spacers. It's just a trial and error process. Grind, put the wheel on, see if it rubs, pull wheel off and grind, etc. etc. I spent over an hour on each caliper.
Old 05-09-2006, 09:09 PM
weaponZ's Avatar
i grinded alot off mine.more than i wanted too.i used some spraypaint to see where they were rubbing between each try.
Old 05-09-2006, 09:25 PM
fastlt1's Avatar
weaponz how much back spacing are you running?
Old 05-09-2006, 10:44 PM
SJM Manufacturing Inc's Avatar
You STILL need long studs. The studs will barely pass 1/2 way through the wheel.
You will JUST about pass tech with 2.5" studs. With spacers, you need at least 3" studs.
Old 05-09-2006, 10:54 PM
LS69TA's Avatar
Yea, same thing I did. Are your wheels 6.5" bs like mine were?
Old 05-10-2006, 09:51 PM
ls2 bait's Avatar
mine are 7.5...is that going to make a diff? i would imagine so.
