1998 hatch release problem..
ive searched and found solutions for the 99' and newer but for mine, the 98', i havent found anything. mine doesnt even have a spring, is it supposed to?
i press the release button 5 or 6 times to get it to come open, then, once open those arms barely hold it up. those could need replacing but that wouldnt cause it to not open huh?
I have the same problem with my 02 and tried every fix that I've heard works and none of them do. I didn't want to hijack your thread so I just started my own. I'll be keeping an eye on both threads someone has to to know why we have this issue. I have to hit my remote 3 or 4 times while pulling up on the hatch to get mine open.
bump to this, also having hatch problems on a 98 t/a...
I used to have to push down and pull up on the hatch to get it to fully release and pop up, but now it just gets totally stuck sometimes and I need to keep forcing it.
LS1Tech Administrator
Received 1,487 Likes
Do you guys have this issue when you open it with the button on the dash? Or with the key? Or is it just an issue when using the remote?
My '98 hatch release works perfect. My '00 used to have issues though.
Originally Posted by Blk98Bird
equal problems on mine with the button and the remote. haven't tried the key in a loooooooong time but I will next time to see.
I wonder if something needs to be lubed with the release assembly? That would explain the sticking issue.
Originally Posted by Mike02Z
My key works fine. It is only when I use the remote or the yellow interior release that mine does not open. I actually have to pull up on mine while hitting the remote 3 or 4 times before it will open. I've given up and just use the key.
Seems that for some reason the release mechanisim isn't as strong when engaged with the key fob or the interior button. Some lube might still be the answer, or maybe a bad electrical connection?
I have to pull up on mine while I hit the button... I tried adjusting the hatch up with the little rubber stoppers, but it still doesnt pop open as it should. still no solution except if I want to replace the mechanism...
