car starts hard when warmed up
Old 05-09-2006, 10:17 PM
xtinctbird's Avatar
Default car starts hard when warmed up
Well my ta has gotten to the point that it starts fine when cold yet if you drive it for maybe 15-20 minutes it gets to where it won't start unless you really pump the gas, otherwise it runs fine any ideas?
Old 05-10-2006, 12:17 AM
Formula WS6's Avatar
fuel pressure regulator.
Old 05-10-2006, 12:47 AM
hotrod_bljak's Avatar
I agree!
Old 05-10-2006, 09:24 AM
OneFast97Z's Avatar
Check the fuel pressure... these members are probably right, but you dont want to replace something and have that not be the problem... sh*t gets expensive when you fix a car that way
Old 11-22-2008, 11:04 AM
crookedbowtie's Avatar
Mine also won't start when it gets warm unless you catch it just right with the throttle. I just put a new Aeromotive reg on it, same problem. I am thinking it just isn't getting enough spark or it it flooding itself...Leaky injecters? A motor would start just fine cold with too much gas,but not so well when it is warm.
Old 11-22-2008, 11:15 AM
the_merv's Avatar
How does the Engine heat affect it?
Old 11-22-2008, 12:18 PM
moehorsepower's Avatar
Check your coil, at times when the coil gets warm if will not produce a sufficient amount of energy to give proper spark to the plugs, This happen to me with a blaster coil. Cold, start up fine, let it warm up and it would shut off, spin over but not start. Put the stock coil back on, drove it all day long..
Old 11-22-2008, 12:26 PM
the_merv's Avatar
I'm suprised you got that with the Blaster.. did you do the ICM Spacer Mod?
Old 11-22-2008, 01:02 PM
Spacer mod? Is this to get it away from heat? My motor is crammed in the bay and it gets warm although the water temp stays around 180 and I am running it with the hood up in the driveway so it should dissipate heat, I would think. I am running the stock coil, but this sounds possible. I have checked for spark and it is there it just won't light it off, Not even with starter fluid. Could it be anything else like in the PCM telling it to not start? Any way to check without replacement?
Old 11-22-2008, 01:09 PM
the_merv's Avatar
You can space it away from where it mounts on the Head.
Old 11-22-2008, 02:58 PM
To get air behind it and get rid of heat?
Old 11-22-2008, 02:59 PM
Could it be air getting past the injector to manifold O rings?
Old 11-23-2008, 01:47 AM
I tried the spacer mod even added dielectric grease, had the ICM tested several times...good. Cold tested the coil resistance and it checked out A Ok. Will test resitance hot tomorrow.
Old 11-24-2008, 07:55 AM
No, I did these mods waaaay back and at that time there was no space mod, at least I did not know about this back in 97..
Old 11-25-2008, 01:13 AM
Still having the floor it to start problem after it is warm. Not leaky injectors, not fuel pressure regulator 40-43.5psi, not coil or ICM (old ones tested good, but replaced them anyway and did the spacer mod), not plug wires, not vacuum leak, injectors are pulsing, and I have spark and full charge on batt, alt also charges at 14.6. New TPS as well, no codes other than a 1661 (I don't have a ses light installed). Idles kind of high.
Quick Reply: car starts hard when warmed up
