LS7 Clutch with Fidanza LS2 Flywheel
Old 05-10-2006, 09:55 AM
Tobynine9's Avatar
Default LS7 Clutch with Fidanza LS2 Flywheel
Anybody running this on an LS1 powered F-Body?
I saw that Fidanza now has part No. 198171, an aluminum LS2 flywheel. Wondering if that will bolt up and work with the LS1 hydraulics just like the LS7 flywheel in the "ls7clutchkit" does.
Old 05-10-2006, 05:47 PM
SOMSS's Avatar
LS7 flywheel will not work on a LS1, you will need an LS2 compatible flywheel.
Old 05-10-2006, 10:54 PM
BackinBlack02SS's Avatar
They are the same thing.
Old 05-11-2006, 06:25 AM
Tobynine9's Avatar
So... you could use the Fidanza LS2 flywheel, LS7 pressure plate, and friction disc all together on your LS1?
Quick Reply: LS7 Clutch with Fidanza LS2 Flywheel
