no good rings for 3.905 in 1/16,1/16,3/16?
Got Wiescos pistons in a 3.905 bore and cant find anything except moly rings.
Anyone know of anyone that has better rings in those sizes?
Called Total Seal and JE.
I always had a bitch of a time finding rings for my old pistons. 3.910, same stack as yours.
The standard moly rings just wouldn't last, and 4" was the smallest I could track down for a hell fire ring.
Part of the reason we found the ring stack first this time, and cut the pistons to match
BTW, best I could do at that time was a gapless top total seal set. Atleast the leakdown stayed solid.
THe issue is the size ring for the Wiesco pistons.
Childs and albert has a chrome plated stainless top with ductile iron second.
I cant find the part number, but thats where I got them.
Pretend I'm stupid So whats wrong with using the Diamond pro-select Plasma Moly ductile top ring and Cast iron 2nd ring that came with my Diamond Dished pistons...?? Are these bad or what??
Originally Posted by KAOS
my w2w sb uses plama moly rings and they said 15psi wouldnt be a problem. so thats my take on it, i dunno though. but like i said w2w said i was good to go
LS1TECH Sponsor
We have a nice ring pack for the 3.905" bore 1/16 1/16 3/16.
It is a stainless chrome top, moly second. It will hold up to anything you can throw at it.
The moly second is a bit of an over kill... however it is very strong.
You can give us a call if you still need some rings. I have one set in stock.
Thanks,
Bryan
LME
713-849-4505
Thanks,
Bryan
LME
713-849-4505
