02 WS6 A4 What is stock idle speed?
Old 05-10-2006, 12:31 PM
02RedWS6RamAir's Avatar
Default 02 WS6 A4 What is stock idle speed?
Car still has low idle, as above mentioned, what is stock idle speed? So far I have changed the fuel filter, pcv, idle air control motor and had the alternator checked. Battery is a couple month old Optima Red top. No SES or codes. I checked all hoses for leaks and found none.
It seems like it's not dropping to 450 RPM's as much, maybe about 500 RPM's at idle. Am I getting closer?
Old 05-10-2006, 01:52 PM
SHINER's Avatar
500-550 is about right, and if you are 600 dont sweat it, 500-550 is completely factory normal!
Old 05-10-2006, 01:56 PM
ls1mongrel's Avatar
Anywhere between 500-600 rpm is ok !
Old 05-10-2006, 02:04 PM
Sounds Good! Thanks for the info guys.
Old 05-10-2006, 02:07 PM
SHINER's Avatar
no prob that why were here, take care.
Quick Reply: 02 WS6 A4 What is stock idle speed?
