converter question
Old 05-10-2006, 01:12 PM
Lason's Avatar
Default converter question
I know this has been asked 1000 times but I cant seem to find a deffinate answer using the search function.
bolting a powerglide to a LS1 using the stock '98 flexplate and the p/g has a turbo input shaft. Can I use any off the shelf turbo converter for this or does there need to be something LS1 specific with the converter? Like the bolt pattern, crankshaft depth, etc.
Thanks guys
Old 05-11-2006, 03:31 PM
malibuman69's Avatar
you have to buy a crank snout extension from gmpartsdirect.com as well as the longer bolts. after that, you are good to go.
Old 05-12-2006, 12:55 PM
Lason's Avatar
Do you have part number? I have been looking for a little while and dont see anything. I even googled it and searched here with no luck.
Old 05-12-2006, 11:06 PM
Lason's Avatar
Thanks for all the input, i found it. Hughes makes a adapter under pn# HP3795
http://store.summitracing.com/partde...5&autoview=sku
**EDIT**After looking at it, it also says it will let me run a older model flexplate as well so I dont have to dump $200 into a TCI SFI approved flexplate. COOL!
Old 05-13-2006, 12:48 AM
Strahley's Avatar
Sounds great man, keep us updated on your project
