4rth to 2nd downshift (Automatic)
Old 05-10-2006, 03:30 PM
Anidote00's Avatar
Default 4rth to 2nd downshift (Automatic)
Hello All,
I'm tunning a '04 GTO with a 4L60E auto. If I'm driving in the mph range of 35-60 and go to WOT, the tranny will only shift to 3rd gear. It will not go to 2nd gear! I'm tunning with EFILive Commercial and I've changed the downshift table at WOT to 76 mph and it still does the same thing!! Am I over looking a table or something I need to change?
Thanks, Cole
Old 05-10-2006, 03:35 PM
white2001s10's Avatar
maybe post up the values in the 2nd gear table.
Old 05-10-2006, 03:37 PM
Anidote00's Avatar
Are you talking about the partial throttle tables?
Old 05-10-2006, 03:38 PM
The kickdown table for 2nd gear.
Old 05-10-2006, 03:44 PM
Anidote00's Avatar
I'm sorry but I'm stupid and can't figure out how to do that.
Old 05-10-2006, 06:56 PM
EFI-live
>Transmission Calibration
----------------------> Throttle Kickdown
is where you'll find the kickdown tables.
Old 05-11-2006, 09:12 AM
Anidote00's Avatar
I've changed them already to 80%. That table is for the TPS position only, so it should kick down when the TPS goes above 80%.
Thanks,
Cole
Old 05-11-2006, 09:53 AM
Thanks,
Cole
There are three of these kickdown tables and they contain TPS vs MPH.
edited to fix errors...
Old 05-11-2006, 03:28 PM
Anidote00's Avatar
You must be talking about the D0906, D0907, and D0908 tables. I've changed those tables as well and still no change.
Old 05-11-2006, 08:56 PM
I'm sorry I told you wrong. The values in the throttle kickdown tables are TPS %.
The tables are D0960, D0961, and D0962.
If you wanted the kickdown-shift from 3rd gear to 2nd gear between 40 and 72 MPH the D0961 table would look like this:
MPH TPS%
0 100
8 100
16 100
24 100
32 100
40 75
48 75
56 75
64 75
72 75
80 100
88 100
96 100
104 100
Is this basically what you have there?
Old 05-12-2006, 09:47 AM
Anidote00's Avatar
MPH TPS%
0 100
8 100
16 100
24 100
32 100
40 75
48 75
56 75
64 75
72 75
80 100
88 100
96 100
104 100
I have mine at 90% all the way down the table. I'm going to try your table and see if it makes a difference. I will let you know the out come!
Thanks,
Cole
Old 05-12-2006, 11:03 AM
Minion's Avatar
On my '04 GTO, the throttle cable had too much slack in it from the factory, which made it very difficult to get it to kick down to 2nd gear. (Basically as delivered, the car would not downshift to second at any speed over about 50 MPH, because the TPS % reading was too low.) Tightening the cable helped greatly. So if you haven't already, you should take a look to see if you are really getting full throttle when you mash the pedal down.
Old 05-12-2006, 12:45 PM
SSpdDmon's Avatar
Also, check the Part Throttle Downshift tables. They have a spot in them for 100% TPS too.
Old 05-12-2006, 05:25 PM
Anidote00's Avatar
I done a scan and it is going to 100% TPS. Thanks for the tip.
Old 05-12-2006, 05:26 PM
Anidote00's Avatar
I'm going to change the downshift tables and see what that does.
Old 05-15-2006, 08:11 PM
Anidote00's Avatar
white2001s10,
I tryed your table and still no change in the down shift. I also try changing the down shift table at 100% as well and still no change. So I'm going to keep doing research on this and see what else I can come up with. Thanks everyone for all your help!
Thanks,
Cole
Old 05-15-2006, 09:13 PM
SSpdDmon's Avatar
Are the WOT tables being enabled? Do you have a value less than 100.00 in the D1206 table?
Old 05-16-2006, 11:03 AM
Anidote00's Avatar
Yes, I have this table (D1206) at 85% and my lower threshold (D1207) is at 75%. How do I make sure that my WOT Tables are being enabled?
