Stainless hose?
Originally Posted by SStolen
I want to change out all the rubber hoses in my engine bay to Stainless. Is there a kit you can buy or a write-up on what sizes/lengths/fittings to get?
Anyone know approx. how much this will cost?
Thanks
Thanks
If you're gonna do your whole engine bay, my advice is do it in stages. Even if you can afford to drop the coin to buy all the stuff up front, the biggest pain in the *** about doing this is getting all the right size hoses/lengths matched up with all the correct fittings for what they attach to. The thing that pisses me off about 4th gens is that for whatever reason GM decided to mix and match metric with standard size fittings on some components. Doing it one component at a time will reduce the possibility of either getting things like your hose #ID's and fittings count/configuration from one part to the next mixed up, or just losing stuff. There really are no writeups or how-to's on stuff like this because there are a million different ways it can be done and not everybody's setup is the same. I got the idea for how to set mine up by just researching other people's build specs and seeing what worked for them.
Last edited by LawmanSS; 05-11-2006 at 11:22 PM. Reason: Non-sponsor link removed.
My power steering didn't run that much. More like 200 with fittings and hoses. But i do agree with the hoses and fittings can be confusing. So plan your lines out well and order accordingly.
Hawk
Hawk
Hawk
Hawk
Originally Posted by rgaynor85
couldnt u just buy the stainless hose coverings and the clamps for the ends that look like fittings.
