16" to 17"?
^^^ what he said
in order to say for sure if anything needs to be changed... need your old tire height and new tire height (example... 275/40/17 ... wheel diameter is 17, sidewall radius is 1/2 wheel diameter + 275/25.4 * .40 (*40 is aspect ratio, it's a percentage of sidewall height compared to tire width... which is what the 275 value is... in mm)
so 275/25.4*.40*2 + 17 = new tire height (replace values w/your tire specs)
so long as new is close to old, no changes needed
245/50/16 to 275/40/17 ill be honest the equation confused me a little bit. i got 23 for the 16 and 25 for the 17???? can someone check this...
thanks
josh
thanks
josh
LOL, wont start huh!?! you wouldnt believe what the guy at monroe muffler was telling me about changing tire sizes. first the 275/40/17, in his opinion, only belong on SUV's, he couldnt figure out why i was putting them on a camaro. second, he told me to take off the 17" and put back on the 16", cause 17" aren't stock for it, it just wont run right. and finally with 16" tires he could save me a hundred bucks. a 100 bucks, whopidity doo! i had a hard time restraining myself from slappin the stupidity out of him!! well, i got a laugh out of it anyways.
thanks for the help!
josh
josh
