Changing brake pads
Changing brake pads
Im sure its a very simple procedure, but Id like any advise on the matter.....How simple is it to change the brake pads? And which pads do you prefer?
Its very simple to change, if you are in there and your rotors are almost shot change them too because its only 2 more bolts. Its two bolts for the caliper pins. Compress the piston with the old pad and a c clamp. Theres these little metal clips that always get lost or stepped on.
I'd get the GM Ceramic pads since the dusting is almost non existant. I have the Axxiss Ultimates now and they dust HORRIBLE. my rims look charcoal
Good luck
Good luck
