Spec 5 clutch squeal....Slowhawk others help
The new motor/turbo kit/built tranny is now in.T56 refreshed and upgraded,SFI 2.2 approved aluminum flywheel,spec stage 5 clutch.ive got between 100-150 miles on the setup now.95% of the time it only squeals when im at a complete stop and engage it to put it into 1st to get moving.Is this normal breakin for people who have used them?im praying it goes away after a couple hundred miles but would like some info from the experienced.Thanks in advance.Nick
Mine's (squeal) still here after 4000miles. It's more inthe way you engage it. Rev little higher next time and let it out quicker. Then it won't squeal. You can't drive it like a sprung clutch...has to be more aggressive.
the 1 thing i cant believe is the pedal pressure and how easy it is to engage.pedal pressure is about stock and engaging is alot easier than the spec 3 i had.ive always been a fan of spec since my stage 3 went 40000+ miles and we took it out to replace it with this spec 5 so it never even gave up.I just wanted to make sure i didnt pick the wrong clutch this time with the 5.....thanks don
Clutch torque capacity is determined by several things. Friction meterial and spring pressure are two of those things. If the Spec 5 friction material has a higher coefficient of friction than the Spec 5 then a softer spring can be used and still get a higher torque rating. In other words, your comparing apples to oranges when you only compare the pedal "feel".
Andrew
Andrew
LS1Tech Sponsor
