IF GOING TO DO EGR MOD SHOULD I GET HOOKER LT'S WITH OUT EGR HOLE
IF GOING TO GET RID OF EGR WITH A NEW LS-6 MANIFOLD SHOULD I GET HOOKER LT'S WITH OUT EGR HOLE
OR SHOULLD I PLUG HOLE
Re: IF GOING TO DO EGR MOD SHOULD I GET HOOKER LT'S WITH OUT EGR HOLE
I never knew Hooker made headers without EGR and A.I.R. provisions. But, if they don't, all you need to do is buy block off plates. There are also some guys on this site who have the tools to make them. The plates are cheap though.
If you get the hookers you just have to get the 14 buck block off plates. I got both the AIR and the EGR block of plates from Speed Inc.
If your intake has no provision for an EGR input then there is no need for and EGR output. Just buy one without the EGR bung since there won't be anything to connect it to on the intake side anyway. If you do get headers with the EGR bung you can make your own block off plate with 1/8" steel flat stock.
