I NEED pics of cut out RIGHT AFTER Y-PIPE! URGENT!!!!!!
I just ordered mine today and I want to have it installed Saturday and I cannot take my car to the muffler shop to have it welded in (b/c I have to take the ACT Saturday)so I need a picture to print out for my muffler man to look at and copy.
I know your thinking that is crazy b/c exhaust will be getting under the car and make everything black and stuff. BUT I am going to build my own turndown to bolt it up so it will point the exhaust outward instead of it just staying under the car.
Josh S.
Josh S.
Re: I NEED pics of cut out RIGHT AFTER Y-PIPE! URGENT!!!!!!
Check out the pic links in my sig. The last two pictures in my yahoo album are pics of my cutout setup. Hope this helps.
Thanks man that helped out and I will use that. But I was kind of hoping that someone would have some pics of a car maybe on a rack or maybe an undershot that shows the y-pipe and then the cut-out joining in. If not I beleive I can work with what you have and get it explained. Thanks a bunch though!
Josh S.
Josh S.
Basically the cutout fits in an area kind of behind the rear seat on the passenger side. If you look there is like a ready made are there. Just make sure they rotate the cutout up as far as possible. If you are going to put a electric power plate like I have on my cutout allow for the motor on the cutout.
I just got mine installed today. There is really only one place that it can go in the "I" pipe. Right under the rear seat is a hump inside - a raise on the underside. Perfect to tuck it away in. I had my Muffler guy weld on a small turndown to deflect the exhaust away from wiring and underside of the car. Its dark right now but I'm installing my SLP "Y" pipe in the am so msg back if ya want me to snap some pics for ya
I haven't reinstalled my exhaust yet, but here's a couple pictures of the cutout in my I-pipe:
http://www.stebbinstinting.com/photo...k/exhaust1.jpg
http://www.stebbinstinting.com/photo...k/exhaust2.jpg
http://www.stebbinstinting.com/photo...k/exhaust3.jpg
http://www.stebbinstinting.com/photo...k/exhaust4.jpg
http://www.stebbinstinting.com/photo...k/exhaust5.jpg
