Definition of WOT
Definition of WOT
I keep hearing that many things get disabled at Wide on Throttle. I was just wondering, what exactly do ls1's consider wot, Is it when the pedal is completely floored, or does it also include when the pedal is like 3/4. What is the range on this?
Something I've wondered as well. Does the PCM "fade" into the WOT tuning parameters, or does it switch at a certain throttle position, what's the low-down, gurus???
I do know AC and EGR turn off at WOT.
it depends on what the setting is. i have my A/C WOT setting at i think 85%. it goes by % programmed. if u wanted, WOT could be set at 5%, although that wouldn't make sense
WOT generally means pedal to the floor, but the computer goes into power enrichment mode (PE) when the throttle is opend a certain percent which is specified in the vehicles PCM.
