AIR, does it affect the O2's?
Ok so when i did my knock sensors apparently i didnt hook up my AIR. So now im thowing a code for the AIR since i do belive its not hooked up
Well if thats the case then am i gonna run rich/lean since the computers planning for added oxygen (from the AIR pump) but its really not going to be there since its off. Would this throw my tune off?
TIA
TIA
The Air Injection Reactor pump injects air into each manifold at the head flange, via an integral runner. The PCM tells the AIR pump how long to stay on after start-up. So, does it affect the 02 sensors? I would say no; however, I'm sure the 02 sensors "see" the slight addition of oxygen content in the exhaust gas, but since 02 content is within acceptable limits, the PCM doesn't care. The extra oxygen ensures more complete combustion upon cold-start. Like BlurLS1 said, once operating temperature is reached, there is no further need for additional air, so the PCM turns the AIR pump off.
In the grand scheme of clean air, blue skies, and butterflys, conjured up by granola-eating tree-huggers, it's a ridiculous piece of equipment. The money spent researching, developing, and manufacturing AIR pump systems could have been put to far better use, clean air-wise, on things like mandating cleaner, gasoline-powered lawn & garden equipment. There is far more air pollution caused by the amount of gasoline spilled every day (VOCs released to atmosphere), than is caused by the small amount of additional emissions released when your non-AIR pump-equipped Trans Am warms up for a few minutes. Ever see an 02 sensor or AIR pump on your garden tiller or weed whacker? How many millions of those things get started up every day?
