What breaks in the 4L60E?
Old 05-13-2006, 08:07 AM
Lasershop's Avatar
Default What breaks in the 4L60E?
Been working on my A4. Its a C5 so I don't really have cost effective transmission options. I now have every single available heavy duty part in this unit and I have been very meticulous about building it as perfect as possible. Built with a feeler gage all the way. 100% thrust roller bearings. OEM 5 gear planets (not cheap imitations). Wide drum w/carbon band. Hard input shaft w/cyro drum. The Beast. All Alto clutches. All new full thickness steels that I polished and debured every one. New updated sprags. Case totally debured internally. New HP ported Pump w/every other mod available. Lot of misc valves and springs. All billet servos. All the best. Transgo stage 2 kit. I have well over 2 grand just in parts not including the Yank SS3600. Thinking about beefing up the case with a welded aluminum "outer skeleton" of sorts. I have heard the case can flex. I have a very thick aluminum after market pan that will really add strength. The case mod will look tricker than **** but is it necessary? Anyone ever broken a case?
Old 05-13-2006, 08:41 AM
Honda Hunter's Avatar
http://web.camaross.com/forums/showthread.php?t=420697
Old 05-13-2006, 08:44 AM
Lasershop's Avatar
Originally Posted by Honda Hunter
Excellent read. Thanks!
Old 05-13-2006, 09:09 AM
Bracket Racer's Avatar
When I broke my tranny the sun shield was the one that broke
Old 05-13-2006, 11:19 AM
1BAD98LS1's Avatar
I wore the crap out of the clutches in a couple of my 4L60's...
Old 05-13-2006, 04:29 PM
WILWAXU's Avatar
Clutches
Drum
Sprag
Sunshell
Once it's had a quality rebuild, you normally only have trouble with the 3/4 clutches.
Quick Reply: What breaks in the 4L60E?
