DR's on a very light car?
Not a f-body but I had to ask anyway.
Would you guys bother with 15" nittos on a very light car (2300 lbs or so with me in it) with maybe 300rwhp and very aggressive gearing? They have 275/50/15 or 275/60/15.
Is it harder to hook a 3500 lbs car with 450rwhp or a 2300 lbs car with 300rwhp, all else being equal?
Originally Posted by BlueSix
If you're drag racing this 2300lb, 300rwhp, aggressive geared car i'd put a full slick on it.
Originally Posted by WhiteSSP
Lighter is always better.
Originally Posted by CrawlinWS6
The lighter the car, the less amount of weight on the tires, causing more traction issues.
I would say it depends of where the CG is. But I would opt for the light car w/ 300rwhp. Less weight = less stress on drivetrain parts. But the good thing w/ a light car is you can actually add some weight and be faster. Alot of guys that race in NMRA are way under the class minimum weight so they stick 50lb weights in the trunk and the car comes in right at or just over the legal limit. -Mark
Originally Posted by 11SECSS
My car is some what light around 3200 and making about 340 rwhp. I know the 17" MT drag radials slowed it down compared to a 17" Nitto drag radial .But the best times came from a 15" ET STREET tire.
Also what is your trap speed @ 3200 lbs/340rwhp? Does 3200 lbs include you?
Weight distribution should be something like 48/52 or 47/53 because the stock engine weights a ton compared to the VQ. So the CG should be further back.
I haven't finished my swap yet but here's what it looks like in an S14 with stock suspension:
Beleive it or not the motor is in the car, just the hood missing!
My trap speed with the 15" is high 116 and best of 117.10 with a 1.61 60ft
My trap speed with the 17" MT is like 113 with a 60 of 1.69-1.72 11.9x-12.0x
My trap speed with 17" nittos is 114 witha 60 ft of 1.63-1.66 11.8x-11.9x
I also tried some BFG's 17" and went 114 with a 60ft of 1.64 11.8x
I think the MT hooked really good and the car bogged of the line then couldn't keep up out the hole plus the few extra pounds of the tires hurt it also weather was about the same conditions . The weight is close to that with me in the car.
