Ls6 Intake on to a 99 egr block off ?
I'm putting an ls6 intake on my 99 ls1 camaro...I need to remove the egr to install correct? What should i use for a block off plate....Thanks
ya you can get the SLP LS6 Intake Manifold w/ EGR or you can get one w/o EGR and tune it out and use block off plates for your mainfolds. or if you get a LS6 w/ EGR protrusion you and don't want to use EGR you can block that hole off w/ a 1-3/8" freeze plug (adjustable/universal kind)
Originally Posted by 99Custom
So do you think the freeze plug would work the best?
freeze plug is fine, do not waste your cash on the slp piece, get a standard ls6 on block of your headers and you'll be fine, I ran the freeze plug for about 2 months, and it was a great cheap fix, it does not look the best, but it is a good solution.
That's what she said...
LS1speed.com sells the blockoff plates.
Enter your car, click exhaust, and scroll to the bottom. I made the blockoff plates for my car out of some 16 guage stainless I jacked from work. I have a 2'x3' plate, it polishes up nice too.
All this 1 3/8" adjustable freezeplug stuff is for blocking off the MANIFOLD, not the exhaust. If you buy an LS6 that doesn't have EGR provisions, ignore these jackasses.
