93 lt1 HELP
Old 05-13-2006, 08:40 PM
bogout's Avatar
Default 93 lt1 HELP
car has 120000 miles on it .Went to go for a drive filled the tank up took off about 2 miles down the road car dies .Still had battery and car would turn over but would not fire. Got car towed about 2 hours later i tryed it again and it started up just fine .I reved it up to about 4 k a few times and let it idle a few more minutes then shut it off.Tryed to restart and nothing.I can hear the fuel pump kick on at start up .At a complete loss at what is wrong .. please any clues or tips. PS opti was replaced at 80.000<<<<. Car runs fine through the full rpm range wot.When it is running.
Old 05-13-2006, 09:15 PM
bogout's Avatar
Default tryed it again
Tryed it again abit ago acted like it tryed to fire up but didnt. Could this be the computer ?
Old 05-13-2006, 10:31 PM
bogout's Avatar
Default tryed again
Ok just tryed again car started and ran. Checked under hood no signs of spark shooting out from bad wires or anything.Could still rev car past 5500 rpm with no problems. then with in about a 3 minutes the car died. no sputer or anything just died like motor was turned off. Starting to think maybe the fuel pump ????
Old 05-14-2006, 09:43 AM
bogout's Avatar
Default any help out here
Any ideals from any one?
Old 05-14-2006, 09:51 AM
V8pwrdz28's Avatar
opti, im 99.9% sure on that, mine did the same exact thing. u can try replacing the ignition coil and ICM, but i would just replace them and the opti at the same time, cuz if the opti is bad, it could hurt the new coil and ICM.
Old 05-14-2006, 11:32 AM
jbird's Avatar
Same exact thing my car did on about 4 of the six optis that have been in it. Let it cool down long enough, and it starts back up. Then when it gets warm enough, or just generally decides to, it dies again. Sounds like opti to me. When my fuel pump went the car would start and run, just like crap, then it would die, it wouldn't rev over probably 2k rpm. Then it would start back after priming it 5 or 6 times and do the same thing over again.
Old 05-14-2006, 01:01 PM
bogout's Avatar
Default ok thanks everyone
Thanks everyone going to try to dig into it next week and see what the deal is.
