pulling TA turn signal housings
I have a 98 TA, both front turn signal housings are loaded with water. I need to get them out so I can tell if they're cracked or not sealed right somewhere.
Should I attack this from the top or the bottom? I searched around and didn't find any recommendations for pulling the whole housing, just the bulbs. Top or bottom doesn't matter...I just don't want to attempt it one way and find out I can't get them out.
2 10mm screws holding the cover, then 2 7 or 8mm screws holding the housing...I did it all through the bottom and it sucked.
Well it wasn't really that bad, but orange water pissed all over my head as soon as I pulled the bulb.
anyone know where to get a replacement lens for this.i have a v6 bird and my housing is round.its seems tough to get at even just to change a bulb.also i cant realy see the inside .do u mean 10mm socket ?and pics of what one looks like and wher ethe screws are located to remove the housing?
