Tranny removal with longtubes
Can the transmission be removed in a 6 speed ls1 f-bod with long tube headers still in place?
It looks fine except for the part of the bellhousing where the starter goes...it looks like it will hit the header. The header hangs over this area about 1/4 inch.
Anyone know for sure?
thanks a lot
thanks a lot
I've done it so many times now without removing a single exhast part including the y-pipe. If you have the height, you can angle the trans down far enough to get it past the y-pipe.
That's what she said...
Originally Posted by '02 SLP#686
Take the tranny out first, bellhousing second
Installuniversity.com has a nice writeup. Click LSx vehicals then install docs. There's a link to the clutch swap.
LS1howto.com has a torque spec list if you can't find some of them on there.
