stat mod
stat mod
Did the 160 mod to my stat and it only reads 188, driveing about 184.I used a 1/8 shim like it said to so why is it not reading around 160.Should I use a bigger shim or what?
Re: stat mod
Few things to consider:
1) The stat will not run the car cooler in non-highway driving unless you do a fan mod to get the air flowing sooner than stock.
I did the auto fan mod: http://ls1info.com/article.php?sid=222
2) The shim size does play a role, and since this is a home made deal it will vary some.
3) Any stat that opens at a certain temp will not keep the car at that temp... the actual temp is usually about 10* hotter. Therefore you might say you made a 175* stat.
4) Last, but not least, the temp gauge in your dash leaves alot to be desired when it comes to accuracy.
Good luck
Dave
Good luck
Dave
