Clutch is starting to slip.........
Old 05-16-2006, 05:07 PM
BlackBirdWs6Zzz's Avatar
Default Clutch is starting to slip.........
So i noticed about a week ago that hard shifting at WOT was NOT grabbing. It took a second to grab and I went uh oh. Not if It is slipping bad in 6th if I put more throttle then it should get. NOT GOOD. SO there goes my cam plans.
Any suggesitons. My centerforce dual friction was VERY good to me. I will NOT go with Spec 3. Any other suggestions? i'm up for something new!
Old 05-16-2006, 06:47 PM
what is everyone else running?
Old 05-16-2006, 07:25 PM
96blkform's Avatar
Spec Stg 3 and have no complaints whatsoever
Old 05-16-2006, 07:35 PM
slolt1's Avatar
same here spec stage 3 love it
Old 05-16-2006, 07:49 PM
I have heard so much bad stuff about spec. you guys have chatter or anything?
Old 05-16-2006, 07:57 PM
slolt1's Avatar
when it gets hot it does chatter not going to lie i have a freind that had good luck out of a 2 and didnt have chatter at all if your not going to have a set of slicks on it droping the clutch at 4000 on the spray then a spec stage 2 would be great for you
Old 05-16-2006, 08:11 PM
Valkyn's Avatar
Spec Stage 4, no springs to fail like the stage 3.
Old 05-16-2006, 08:19 PM
is the LT1 design better then the LS1 design for these clutches?
How much will a stage 4 run?
I hear it's usually the pressure plate to go(then all the **** blows up)
Quick Reply: Clutch is starting to slip.........
