Header capped itself a hole in the runner tonight!
So I was driving home tonight from work and heard a LOUD boom and then the motor started making this tapping sound. So I stoped right away on the side of the road and the freakin #3 runner on the right side header had a hole on it!!! Yes a hole... about 1/2 inch in diameter on the primary close to the flange.
This is not normal is it, I'm not even running nitrous or FI to get the headers that hot or anything!
1 Post
Originally Posted by klujan13
from your pics those look pretty rusted...maybe it just gave way from the exhaust pressure. but thats definitely not normal!
How long have they been on the car
It was probably a random flaw in the metal that nobody saw
Originally Posted by Lithium
Is it just me or does it look like hammer marks all around the hole???
EDIT* Yeah I am seeing things, nevermind.
The headers are not rusted, its just surface oxidation from humidity. They are less than a year old.
Originally Posted by CW00BlackTA
There is something wrong with your headers. I am speaking about the material itself. That looks like a brittle fracture (no deformation around the periphery) which would indicate the tubing had been improperly heat treated. It should be nice and ductile and if it was, there is no way a hole like that would result. Stainless steel is susceptible to embrittlement if the wrong grade is used for welded applications.
There was a guy here locally that recently had a set of Pacesetters do the same thing. It's either a weak spot in the material or IIRC Bo White said that he has seen this same thing also caused by a lean condition. Do you know what your EGTs are?
