lt1 firing order??
Old 05-16-2006, 10:33 PM
Taubr Unit's Avatar
Default lt1 firing order??
did a search and got nothing..... pulled all my wires off and need to put back on. Whats the firing order and how do i tell what goes where on the cap. Its not a reg. cap anymore from what im used to. are lt1 still 1-8-4-3-6-5-7-2?
Old 05-16-2006, 10:40 PM
Greaseymec's Avatar
Yep.
Mec
Old 05-16-2006, 10:41 PM
Jditlfm's Avatar
http://shbox.com/1/engine_specs.jpg, and yes yours is right.
Old 05-16-2006, 10:44 PM
Taubr Unit's Avatar
ok, but now whats what on the opti?? there 4 on 1 side and 4 on the other. whats what cylinder?
Old 05-16-2006, 11:59 PM
rob97TA's Avatar
if you look on the sides where the wires connect to the opti, they shoudl be numbered, you might have to clean the opti off a little like i did if its kinda dirty, but the spots should be numbered, if i find a diagram somewhere i'll post it.
edit: found you a diagram
Old 05-17-2006, 12:14 AM
Taubr Unit's Avatar
hell ya!!! thanks bro
Old 05-17-2006, 02:00 AM
the_merv's Avatar
After I found it, I wrote it on the front of the Opti next to the connections where it is visible, so it makes it real easy. That might help.
Quick Reply: lt1 firing order??
