Quick ? about 2001 Vette cam
Is there a difference between a 98 Camaro LS1 cam and a 01 Vette LS1 cam. I thought the 01 was a LS6 cam. If so how much of a HP gain can I expect? 30HP? Thanks in advance.
Joshua
Joshua
The standard 01 Vette cam is NOT the same as a LS6 cam. While the specs may vary very slightly it is basically the same as your stock cam in your 98 LS1. You can expect zero horsepower gain.
Originally Posted by orangeapeel
I don't know if you can pick up 30. Maybe 15 and depending on other mods.
