Throttle body cable question..
I was cleaning up my engine bay the other day, and noticed how filmsy my throttle body cable was. If I push down on the cable it goes down quite far. My question is, is it supposed to be like that or should it be tight? Hope I made sense here.
Originally Posted by presto_z
you can adjust it to be tighter.... just do some searching on here...
depends on how loose.... if you can almost unhook it from the linkage they i would say yes..... it doesnt have to be super tight, but obviously the less slack the better throttle responce it will have
here is a pic
http://www.mylivingtree.com/7199pic/714/CP793714.jpg
there are plastic clicps that lift up and u can slide it either way... you will see when you look.... i need a job like that....
