Big cam in Cam Only ls1
So is the biggest cam used on Cam only ls1's the T-ReX?And just out of curiostiy how fast and how much power has been made with that cam?
I have an 02 Trans Am th400 4500 stall full suspension 3000#s with driver cam only but I think my cam is a lil different than the T-Rex..
Any info is appreciated..Thanks
T-rex is designed to WORK with stock heads, but by adding heads to the setup, you will gain power just like any other cam. Main reason that people say that its designed to work with stock heads is that it still has PTV clearance without flycutting the pistons. That statement is very misleading.
The TRex is the largest you can fit without flycutting. I believe a 250/254 on a 108 would require flycutting. If you went with the TRex you could get a "cheap" set of CNC LS6 heads from TSP and probably see close to 440 rwhp. It sounds like you already have your weight, suspension and stall prepared for a large cam, so I'd go for it!
Originally Posted by TJ
cant if you go with a max effort cam like the trex or the MS3, will be PTV issues.
Originally Posted by 67camaro
but he has 6.0L heads. dont they have 72cc combustion chambers? he has plenty of room to bump it to at least 10.5:1.
same valves, springs etc. you MIGHT be able to get by with a bit more because the lq4's have a dished piston somewhat.
