crank pulley problem
I stripped the first few threads in the crank . After taping it out it seems to be alright.
My question is should I be worried about stripping them even more when I install the pulley?
If so is there any other way to install the pully on the crank.
Any ideas?
Any ideas?
That's what she said...
Make sure you run the old bolt all the way in and out a few times to make sure it's not going to get ugly.
I would put the pulley in the oven for a while before you try to install it with the threaded rod/washers/nut as mentioned above.
After you get it fully seated, remove the nut/rod and install the new bolt. You might want to be a little less crazy on the new bolt considering the lack of threads.
Or a wooden board and a rubber mallet! I noticed some rubberish material on my SLP pulley and chose not to bake it; was this really an issue or was I being paranoid?
The reason it's so hard to get on while cool has alot to do with how tight they want it to be when it heats up. Being supertight while cold preloads it so it'll stay tighter at operating temperature.
