Drag Racing Tech
Battery Relocation Cleanup
Old 05-18-2006, 12:54 AM
DOUBT IT's Avatar
Default Battery Relocation Cleanup
Here's some new pics of my setup up front. I took the measly factory ground off, and made a new one out of 2 ga wire. I also ran the wire differently.
OLD SETUP:
NEW SETUP
In the last pic, you can kinda see the catch can that I installed. I couldn't stand to see that ugly battery tray there anymore, so I deleted it and installed a Jaz catch can down below where the tray was. It's bolted through the inner fenderwell, and mounted quite well. Here's two more pics...
Here's the only downside... You can see the catch can through the foglight hole, if the lighting is right. I had to get the camera to flash to see it. Otherwise, it's invisible.
Questions and comments are welcome.
Old 05-18-2006, 08:10 PM
INTENESS's Avatar
Nice job man,Going to be doimg that to myself soon.
Old 05-18-2006, 09:00 PM
Restricted User
76LS1BIRD's Avatar
I made this for my 98 TA,it bolts down where the bat. was.
This makes going back to stock easy. Dale
Old 05-18-2006, 09:10 PM
Phoenix 5.7's Avatar
looks good. how big of a catchcan do u have? when i relocate my battery, i want to get rid of the factory battery tray/coolant overflow.
Old 05-19-2006, 12:12 AM
DOUBT IT's Avatar
It's the Jaz recirculating tank from Jegs. It's about a quart IIRC. It does actually recirculate too. I know I saw a thread not too long ago about whether or not it does, and mine does for sure.
Old 05-19-2006, 07:23 AM
Race your car!
JL ws-6's Avatar
I like that... can the catch can be painted you think? I'd just want to paint it so there's not a big red thign sitting in there... wouldnt' match the rest of my car LOL.
I'm planning on replacing my battery with a LW odyssey one, but keep it up front, I figure that would save more weight then moving to the rear, and I wouldn't hav eto go thru all that nhra safety stuff for a battery in the trunk... make life alot easier. Not sure how I'm gonna mount it yet, maybe on teh batery tray laying on it's side.. gotta get the battery and pull everything out, and see what would be the easiest way to mount it securly.
Old 05-19-2006, 06:01 PM
DOUBT IT's Avatar
You can get them in black.
Old 05-20-2006, 06:47 AM
Race your car!
JL ws-6's Avatar
Well then, there's a simple solution! Do you have the part # for that thing? I"ll pick one up next time I have to order soemthing from Jegs. A good pic of how you mounted it would be good too.
Thanks!
Old 05-20-2006, 09:16 AM
Loudmouth LS1's Avatar
OLD SETUP:
NEW SETUP
Hey, where do you get the distribution block from, i've been meaning to pick one up and redo mine a bit neater up front!
Old 05-20-2006, 10:07 AM
BubaGumpShrimp's Avatar
only things i would say is paint that sucker black and make a cover for that hole and paint it to match.
Old 05-20-2006, 06:04 PM
rocketman442's Avatar
You can get the distribution block at a stereo store.
Old 05-20-2006, 06:18 PM
a98ws6's Avatar
Maybe I am overlooking something, but where are the battery cables now? I want my setup to be like yours because I dont want to see the old wires.
Old 05-20-2006, 06:28 PM
DOUBT IT's Avatar
The positive is the big red cable in the first picture. It's loomed now, and is zip-tied to the clear ground cable that I made to replace the ugly stock negative cable in the first pic.
If you guys want closer pics of anything, just ask.
Old 05-20-2006, 07:33 PM
Cool, thanks!
Quick Reply: Battery Relocation Cleanup
