intake swap
intake swap
I swapped my intake for an ls6 today and I picked up a check engine light and its not finding idle. I checked my vacuum lines and everything seems to be in place. Is this normal and I just need to get my tune updated now or do I have a problem?
An easy way to check for a vacuum leak is, with the engine running, spray all over the manifold where it meets the head with throttle body cleaner or starter fluid....if your engine RPMs go up, you found the leak....I'd spray over the vac lines connecting to the manifold also...just try to spray in every nook & cranny where a potential vacuum leak could occur.
Originally Posted by blackbird345
Not sure if you touched the wiring going to the coils on either side but if you unpluged it you would only be running off of 4 cylinders and be similar to what you're discribing.
Make sure you reattached the little vacuum tube that goes on the MAP on the rear on the manifold....
