Lexan Windshield Install?
Anyone have any pointers to install a lexan windshield? I just got a Pro Glass windshield and it is oversized to trim as needed. I found out that you can install it like a normal windshiel or use sheet metal screws with weather stripping (for hieght adjustment). I plan on doing the countersunk screw method, but how do I go about trimming the lexan? What is used, just a cutoff wheel? Also how far apart do the screws go around the perimeter? Better yet, is there an article online somewhere? Thanks for any help.
LS1Tech Sponsor
Use a jigsaw with a 18 tpi blade. Trim till you are 3/16 from fitting. Then sand with a grinder with 80 grit till it fits. Final sanding to clean and straighten the edges use 200 grit sand paper on a 1" X 2" wood block.
As for screws I use 8 x 32 countersunk SS screws. I drill and tap all the holes.
If you will call me I can FAX you the instructions for proper spacing.
877-516-7223
877-516-7223
buy, camaro, car, corvette, drag, install, installation, installing, lexan, ls1, ls1tech, racing, top, windshield, windshields
