problem removing transmission
the transmission is catching on the floor of the camaro and only has like an inch of spline to comeo outta the torque converter. its a ls1 fbody, anyone got ideas
well it came out w/ the converter. the conv to flywheel bolts were torqued waaaaay too tight from the last dumbass owner. 44ft/lbs shouldnt have me lifting my whole body in the air when im losening the bolts.
use a sawzall and cut the floor out so you can "fred flinstone" it
yeah never remove a tranny without the converter
i agree with him that youd be surprised as in how tight the bolts can get or seem to get after a period of time heating up and cooling down.
good luck.
i bed fred flinstonin it will give you at least 5 more HP and if not it would look funny as hell....
ok im done i must be tired! LOL
good luck.
