P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage question...
Old 05-18-2006, 07:51 PM
MattIROC's Avatar
Default P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage question...
Searched for this, and didnt come up with anything. My temp gauge stopped working, so I bought a new sensor from GM. Put it in, works fine now, but the P0118 code keeps coming back. The wiring looks fine, and nothing is on the wiring or sensor. What would cause this? 98 TA...
Old 05-18-2006, 08:37 PM
jeremymcclure's Avatar
im not sure about the TA's but i know that some cars use 2 temp sensors. one for the guages and one for the motor.
that would be the first thing to check
Old 05-18-2006, 08:50 PM
Moderator
jimmyblue's Avatar
Measure the voltage at the PCM and the sender,
and see if (1) they agree, (2) they are in a normal
sort of range (couple of volts). An open circuit is
the likeliest way to get high voltage. Connectors
can look fine with a pin pushed back, etc.
Quick Reply: P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage question...
