broken pin on PCM!?!?!
Old 05-18-2006, 08:00 PM
jeremymcclure's Avatar
Default broken pin on PCM!?!?!
hey everyone.
i just got my motor the other day and it came complete with wiring harness and all excessories.
there is just one problem,
PIN 76 on the blue plug is damaged. its the pin for Oil level Sensor Signal. does anyone have an extra pin laying around with a little bit of wire attached to it?
I figure that way i could just splice it in, it doesnt really matter what color it is, i just want to keep all the wires there that are supposed to be there, i prob could pull one out for the trans seeing as im not going to use it but i'd rather leave em all there just in case.
if anyone has those plastic peices on top of the harness that would be great too because one of them is broken in half! on the same blue plug of coarse. I think they call them guards or something..
the motor is a 98 LS1 out of a firebird
thanks in advance guys!
-jeremy
Old 05-19-2006, 05:19 PM
Gary Z's Avatar
Any GM service department should have a connector repair kit.
Old 05-21-2006, 12:16 AM
acually i solved problem, i used a pin off the main A4 harness that i removed out of the harness. it even had the brown wire and all!!
thanks anyway guys
