LS2 402 ETP 245 Results 535 RWHP SAE....
Old 05-18-2006, 11:16 PM
Nickn20's Avatar
Default LS2 402 ETP 245 Results 535 RWHP SAE....
LS2 402 short block from Scoggin Dickeys.
Cam is a 246/248-115 .61x lift on both intake and exhaust
FAST 90 with LS2 TB
Custom cold air intake 4"
ETP 245 CC heads 72 CC chamber 10.7:1 compression ratio (91 octane)
Kooks 1-7/8s headers
ASP UD pulley
SD tune by muah, lol
I was hoping for more, motor still has less than a 1000 miles, maybe it will break in more?
Enjoy!
Old 05-18-2006, 11:17 PM
Ben R's Avatar
Why the big loss at 6,200?
Old 05-18-2006, 11:30 PM
Nickn20's Avatar
I think its intake manifold restriction..... it does look unnatural, I may try shimming the valve springs a little more, I already had to shim them .045 install heigth I beleive is 1.745 I think I can go another .015 without running in to bind.....
Old 05-18-2006, 11:44 PM
ls1408cp's Avatar
is this a 6speed or an auto
Old 05-18-2006, 11:59 PM
V-10 Killer's Avatar
That seems damn close to what I'm finishing up right now. Hopefully now I have an idea what mine should be capable of.
Congrats on the killer numbers
Old 05-19-2006, 12:00 AM
DrkPhx's Avatar
Looks like a 6-speed. Why the low static compression? What thickness head gaskets did you use?
Old 05-19-2006, 12:29 AM
verbs's Avatar
Originally Posted by Nickn20
I think its intake manifold restriction......
I've never seen a FAST 90 do that....
Old 05-19-2006, 12:57 AM
Nickn20's Avatar
I am open to suggestions, what do you think it is? anything other that what I am have mentioned already?
Old 05-19-2006, 01:54 AM
ls1408cp's Avatar
not trying to steal your thead but i went this route. I should have it up in running in about 2-3 weeks.
Old 05-19-2006, 01:58 AM
Nickn20's Avatar
No prob, I tuned this car with that intake on it about 3-4 weeks ago..... Id love to do a 402 with that intake port matched! hehe.
Link to thread....
https://ls1tech.com/forums/dynamometer-results-comparisons/498289-victor-jr-intake-etp-225s-big-bore-383-dyno-results.html
Old 05-19-2006, 02:23 AM
ls1408cp's Avatar
seems like all these et heads have a problem in the 6200-6500 area wtf. has anyone fixed on of these by changing valvesprings
Old 05-19-2006, 03:45 AM
SuperSporttruck's Avatar
Nice numbers !!! You should look into porting the FAST to pick up a little more air flow. If not you gotta go sheet metal. You will obviously pick up some more as soon as the engine is broken in as well. Keep us update. I am putting together a 408 with around the same set-up.
Old 05-19-2006, 11:41 PM
Collections Hold
Cary@Perf-Induction's Avatar
Default 62-6500
We see the same thing with the PSI valve springs. I talked to Nick earlier and told him to try the LS2 manifold. I have had a few customers swap out the fast intake with the LS2 and carry out much harder after 6000. I would like to see a swap to back this up.
Old 05-19-2006, 11:50 PM
xfactor_pitbulls's Avatar
Never heard that before..................Everyone I know that has compared the fast to ls2 has done better with the fast, stock cubes or 427.
Brandon
Old 05-19-2006, 11:56 PM
ls1408cp's Avatar
so are the psi springs junk
Old 05-20-2006, 01:55 AM
Collections Hold
Default Psi
No they are not junk. That is not what I was saying. I feel that it is an air supply issue. We have run several different springs. They more aggressive lobes,( lsk) etc. were more stable with the psi springs.
Old 05-20-2006, 01:57 AM
Collections Hold
Default ls2
Brandon
Maybe so, but with which cylinder heads?
Old 05-20-2006, 02:12 AM
Blown04Z06's Avatar
wow that is awesome! i have a fresh LS2 403ci sitting in the garage. i need to make some more money to finish out the build. after seeing these results and others on this forum i know where i need to put my money into, heads, cam to match and the right intake.
Old 05-20-2006, 02:24 AM
ls1408cp's Avatar
I must have took it the wrong way.
Old 05-20-2006, 09:36 AM
beardWS6's Avatar
My 408 with ET 245`s are toping power around 5500rpm`s. From everything we see the intake is holding me back bigtime. these ET heads just out-perform the fast set-up. You can see it in my dyno sheet also. If I would have know this I might have went with a set of 225`s instead. But O`well, I will tough it out. I`m planning a new intake next year to match my set-up. I`m going to wait and see what everyone comes up with. But on another note. I had over 500rtrq locked with this set-up under the curve. I promise, at 40-50 roll I can smoke them with this A4 set-up. Monstor TRQ!! all threw the curve for me!! I do love it
Quick Reply: LS2 402 ETP 245 Results 535 RWHP SAE....
