LT4 HOTCAM spec qeustion!!!
Old 05-19-2006, 07:35 AM
Wickedws6ta's Avatar
Default LT4 HOTCAM spec qeustion!!!
Does a HOTCAM kit give you a noticable difference in horsepower if so how much????
Old 05-19-2006, 07:56 AM
LT1BRN's Avatar
the full kit, with all bolt ons should push around 350 Hp with a good tune, or so I was told, my car is in the final stages and should be on the dyno soon, I will post the results as soon as I get them.
but what are you looking for, quite frankly if I get didnt that good fo a deal on it I would have gone with a bigger cam.
Old 05-19-2006, 08:02 AM
I like the hotcam kit i think but thanks for your help and send me those dyno specs when ypu get them.
Old 05-19-2006, 03:34 PM
WHITEBIRD's Avatar
if you want one i have a new hotcam kit for sale. cheap
Old 05-19-2006, 05:56 PM
skatinjay27's Avatar
how cheap?im in the market
Old 05-20-2006, 02:51 AM
kamiczo's Avatar
I put 327rwhp and 335rwtq with the Hot Cam and Lt's.
Old 05-20-2006, 05:28 AM
Kizzle's Avatar
I put down 330 rwhp and 345rwtq on a Mustang dyno with just the hotcam kit with LTs and ORY. Still missing a lot of bolt-ons, so there is still a lot of room for improvement.
If you want to see the dyno graph and pics:
http://www.projectcamaro.net/forum/s...ead.php?t=7498
Old 05-20-2006, 05:56 AM
LT1BRN's Avatar
this is what I did to my car and I hope I put down 350+whp, If I get 350 I will be really happy, aything more (whish I highly doubt) would be great.
Performance Mods: (Overhauled Engine)
.020 over size pistons, cam, fully roller valvetrane
(1.6rr's, springs, retainers, locks.. etc), Hardened push
rods, New heads with hand p&p, 58mm BBK TB, Moroso cold air
intake with High flow trick flow elbow , Hooker long tube
Headers, Ory, Magna flow cat back, ! all emission BS, fully
built A4 with trans Go Shift Kit, TCI torque converter.
Transmission oil cooler.
Non performance:
new cooling system, new fuel lines, new water pump, new oil
pump (high volume), new filters and fluids all around, new
wiring all around, including ignition and spark plugs, New
sensors all around.
I'm sure there is something that I missed, adn I might change the TB from 58 to 52, Im not sure yet.
Edit, wish some one would give ma an insight about the mods and the TB size.
Old 05-20-2006, 10:53 PM
Public Enemy's Avatar
Non performance:
sensors all around.
i think u will do around 330-350whp.. which tuning program did you buy?
Old 05-21-2006, 04:02 AM
LT1BRN's Avatar
didnt get one yet, but will be getting tuner cats.
Old 05-21-2006, 04:28 AM
good luck with ur project..
Quick Reply: LT4 HOTCAM spec qeustion!!!
