Vette rear o2 sensor $180 each!
That's what the Stealership just quoted me for the OEM part (25317697). Does SPDC sell these? Or maybe I should go with the 13111 Bosch, Advance quoted me $80 for those.
Where's a good place to get a pair of rear Vette o2 sensors?
TIA
TIA
https://ls1tech.com/forums/generation-iii-external-engine/500407-egr-air-o2-sensors-motor-tranny-mount-faq.html
People use rear ones in the front when they run headers due to the better heater.
Originally Posted by 2K2WS6TA
I think you misunderstand, the vette rear o2s can be used in the front o2 sensor position (the ones you need) on the F body
That's what she said...
Originally Posted by BrandonDrecksage
the rear o2 in a fbody are useless...right? is the vette the same way? if it is..why not tune them out?
We are saying that the 'vette REAR O2 SENSORS (the physical sensors that screw in) work well when placed in the FRONT O2 SENSOR POSITION on an F-body.
You will have nothing plugged in/screwed in in the rear O2 sensor position still, which is what you have tuned out.
