msd 6ls
The box is p\n 6010...The harness is p\n 8886...I have the box already but the harness is just now being released...I just don't understand how people are saying that they suck or whatever when they can't even get the harness...I'll keep everyone that is interested updated...
I'm curious why you dont use the stock pcm to do teh spark thing...
MSD does make some replacement coil packs for ls1's(and they are better than the stock coil packs)
is the box just becasue of teh 2 step?
cause if it is..you might have better luck getting a harlan 2 step...
and now HPT has 2 bar for 98's
if you need 3 bar you can use the 2 bar..its easy to set up and the 2 bar and 3 bar use the same size ve table...
I am now running the 6LS and so far all is good. The box has timing curves and you can set a min and max timing advance, it also has a 2 step and a timing retard for us nitrous guys. I also have line locks on my car and have setup a relay so that I can flip on one switch and use the line locks for a burn out then pull up to the line flip the other switch and set the 2 step with line locks. The ground is being controlled by a button on my shifter ****. This is all theory right now but this wednesday I will put it in action to see how well it works.
