Anyone have the voltage formula for 3 bar GM map?
Old 05-19-2006, 11:20 AM
eb02z06's Avatar
Default Anyone have the voltage formula for 3 bar GM map?
Just what the title says-thanks!
Old 05-19-2006, 11:55 AM
Boostaholic's Avatar
Far as I know its liner as follows.
-14 --- +28 0v --- v5
Old 05-19-2006, 02:32 PM
Moderator
jimmyblue's Avatar
Here is a fly-sheet from Delphi for one of their turbo
3-bar units. From what I've seen there is some variation
in the details, endpoint voltages may be variously 0.25
or 0.5 at the low end and 4.5 or 4.85 at the high end.
Odds are if you have the part number you can Google
up the proper document (this is where I got the .pdf
from, .pdf is too chubby to attach so I converted it to
a compressed image).
Attached Thumbnails Anyone have the voltage formula for 3 bar GM map?-turbo_map_sensor_delphipdf.png
Old 05-19-2006, 05:36 PM
eb02z06's Avatar
I found this linear table for 2 and 3 bar but if you look closely the value for voltage 1.10 is missing.
http://hhscott.com/93tmv/docs/chris_...conversion.xls
