Generation IV Internal Engine - Got the build sheet for my 427
Scarecrow
05-19-2006, 12:50 PM
Got my build sheet yesterday for my new motor. It is a Darton MID sleeved LS1 block with LS7 heads and intake. Even with the baby cam going into it, we expect to make @560 rwhp AND @540 rwtq N/A (shooting low :jest: .. this motor is capable of well over 600rwhp N/A as you have all seen from some recent posts. :) ). 11.5:1 compression...
1 month to go and it will be finished! :fluffy:
Here's the build sheet:
New GM block - Darton Sleeved - Decked - Squared - Line Honed - 4.125 bore
Callies Crank - 4.0 stroke
Callies Rods
Mahle pistons
Mahle Ring Set
Clevite Bearings
ARP main studs, head studs, rod bolts
GM LS-7 Heads
GM LS-7 valves
Harland Sharp Adj Roller Rockers
Custom Spring Set
Titanium Retainers
Custom Comp Cam --- very docile
Comp Lifters, Push Rods
Rollermaster Dual Row timing set
GM gaskets
Cometics Head Gaskets
GM Block Set
Custom Ported Oil Pump
GM LS-7 Intake Manifold
GM Performance Valve Covers
Katech Belt Tensioner
Custom RevXtreme 90mm TB & Fuel Rails
Ron Davis Dual Pass, Dual Row Radiator
Thunder Coil Relocation Kit
LS-2 Water Pump
SLP Crank Underdrive Pulley
GM 85mm MAF
42lb Injectors
11 Bravo
05-19-2006, 01:53 PM
Looks good. You should have got an Evans pump to go with the Evans coolant that you need for those Darton sleeves.
Phoenix 5.7
05-19-2006, 01:56 PM
nice. should make a fun very streetable car
Scarecrow
05-19-2006, 04:39 PM
Thanks. That's the idea. :devil: This is going to be daily driven. I'd like to take it out to Sebring soon.
Bravo... I will take a look at the Evans. There's a little time left. :D
11 Bravo
05-19-2006, 05:19 PM
Yeah, if it's the MID wet sleeve then the man who designed them recommends Evans coolant and pump. For a block that expensive I wouldn't cut any corners. Good luck.
strokedls1
05-19-2006, 05:44 PM
My friend had problems with false knock on the slp underdrive pulley. Take a look at the march or ati crank balancer. Otherwise it looks like a beautiful combo. I'm sure you'll make lots of power with those heads and intake.
Beast96Z
05-19-2006, 05:56 PM
Agreed on the water pump. The LS2 is worse than the LS1 anyway. The evans pump and coolant are the only way to go for the MID.
11 Bravo
05-19-2006, 06:16 PM
The only thing about the Evans pump is that it makes you cringe when you have to spend almost $500 for a belt driven pump. That one hurt when I clicked the "confirm order" button :jest:
Beast96Z
05-19-2006, 06:47 PM
The only thing about the Evans pump is that it makes you cringe when you have to spend almost $500 for a belt driven pump. That one hurt when I clicked the "confirm order" button :jest:I know it. I think I'm gunna sell my Meziere and get one so it shouldn't hurt to bad. :)
gator's 99TA
05-21-2006, 11:05 PM
must be nice!!!!
chuntington101
05-22-2006, 06:46 AM
if you dontmind me asking how much would one set you back??
thanks Chris.
Z O SICK
05-22-2006, 09:59 AM
thanks Chris.
X2, i would like to know as well.
I would rather buy an LS7 Crate motor than sleeve an LS1 block.
Just my .02
WS666
05-22-2006, 10:21 AM
Our Joeseph is growing up so fast... seems like just the other day he was swapping out his first cat-back on the car!
gun5l1ng3r
05-22-2006, 11:27 AM
x3 on the cost.
I wanna know how many decades I am going to have to save to get one in my car.LOL!
Scarecrow
05-22-2006, 11:39 AM
It WAS just the other day. :D
must be nice!!!!
cost??
PMs Sent. The time and attention to detail behind the assembly of this engine is top notch.
Just my .02
There are plenty of sleeved motors running around with no issues. This engine is being built to handle a lot more abuse that it will ever see, so I'm not concerned. :)
diognes56
05-22-2006, 12:12 PM
Love the new sig Joe. The car is going to be a beast :D .
David
LS1Aggie09
05-22-2006, 12:53 PM
definitely going to be one sick ride...would you mind pming me the cost as well? What else do you have done to your camaro to go along with this kickass motor?...main question being is it the stock T-56?
Zerskijpac
05-22-2006, 02:47 PM
Wow, thats awesome man.
good luck.
Scarecrow
05-22-2006, 03:33 PM
good luck.
Thanks!
The T56 has upgraded synchros, shift forks, bearings, etc.
It has a SPEC 3 right now, but a SPEC 3+ is planned.
Some other stuff on (or will be on) the car:
Kooks 1-7/8" x 2" stepped LTs to a Corsa Catback.
Racetronix in-tank fuel pump
BMR K-Member
Kirban shifter w/Lou's short stick
KBDDSFCs
Bilstein HDs
BMR LCAs & STB
Granatelli Adj PHB & Lowering springs
Fikse FM5s.. Black anodized centers
VFN "Sunoco" Hood
SS Spoiler
32 & 21 mm swaybars
Strange Dana S60
It's meant to be a fun daily driver. Take it to the strip, Sebring, Saturday night hangouts, car shows, and the grocery store. :D
SuperSporttruck
05-23-2006, 02:19 PM
When did Harland Sharp come out with LS7 offset adjustable rocker arms, and how much are those ??????
Scarecrow
05-23-2006, 03:18 PM
My engine is getting the first .. or one of the first ... of the new Harland Sharp rockers. Not sure on price. I'll have to ask.
gator's 99TA
05-23-2006, 11:07 PM
dana 60 huh?
interesting.....
Scarecrow
05-23-2006, 11:42 PM
Yeah... talked to a local guy about it. He's getting one and swears by it. I wonder if his has arrived yet. :D
