Throttle Body and MAF Air Sensor
Hey, First time posting here, came over from ls1.com and pro-touring.com...GREAT SITE <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> Seems Like a very responsive place!!!
Anyways I'm looking to use an LS6 in my pro-touring Camaro Project, the Engine is eventually going to be made to use CAS F-Body Twin Turbo Kit (Stage II) But before thats done I wanna do some cheaper performance mods...and I was wondering what is the largest/best/most efficient Throttle Body and Air Sensor Combination for a stock 2003 LS6...(Manufacturer)..I've only seen the Throttle Body's to 80mm and I've been loooking at the Granetelli MAF Sensors...
Thanks for any help in advance,
Ralph
Ralph
Re: Throttle Body and MAF Air Sensor
To delete multiple posts/threads click the "Edit/Delete Post" icon above your post. Then check the "Delete Post?" box. Finally, click the "Edit Post" button. If you would like to delete an entire thread that you started you can do so by simply deleting the original post that you made to start the thread.
BTW, being careful to only click the "Add Reply" or "Add New Topic" buttons only ONCE will help to make multiple posts/threads a rarity. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
